MatchSrf vs. -MatchSrf stored Refine match Tangency tolerance unit
In V5, V6, and the WIP, it appears that the GUI version of _MatchSrf reads and stores the Tangency of Refine match in radians, whereas the macro version does so in degrees. This results in an undesired default value whenever switching between the GUI and macro versions.
This can be tested by setting the value to 1 in one version of MatchSrf, completing the command, then doing the same in the other version:
Setting Tangency to 1.0 in -MatchSrf results in MatchSrf displaying 57.29578
Setting Tangency to 1.0 in MatchSrf results in -MatchSrf displaying 0.0174533
Ugh. Thanks, I’ll check that.
https://mcneel.myjetbrains.com/youtrack/issue/RH-52366
