I have a problem trying to cut the red segments between the circles
could someone tell me how to do it?
and here is the file i use
matching component.3dm (26.7 KB)
matching component.gh (5.8 KB)
Best upload your file, otherwise we have to recreate it before trying solutions.
See: How to ask effective questions
here is the file ,thank you for answering
Wow! that’s alot of work
thank you so much
but no, that wasn’t the result i needed
If you need only those parts of the segments that are inside the circles, then @HS_Kim’s solution does do that. If that’s not what you’re after, then you’ll have to elaborate a bit further.
Seems like you want to generate parametric tree plan view for landscape drawing…
you’re right, i’m doing a landscape
thank you so much for your sincere help
