A rather simple issue which for some reason I cannot figure out;
A Tmatch component has a list of two branches which it is trying to match with another list of two branches. For some reason, I keep getting negative matches even though they are positive. I am not sure what the underlying issue is?
The contents for the pattern are similar in index item 0 to 2 in the first branch, yet returns no values for the corresponding grafted trees {0;1} and {0;2}. Additionally branch {0;3} also seems to be empty while there should be plenty of positive matches.
I added two starts text to the pattern text because I care about all the items which include this text, amongst other text.
Thanks for your reply. Unfortunately member Index does not quite do the job as I am also interested in indexes where only part of the text matches, hence the * * I add.
I’m not sure what you mean by branching issue? Can it be resolved, or do we need to think of a workaround?
you grafted the 8 text items that were also in {0}{1} so now they don’t match {0;0-3}{1;0-3}. you would need to have corresponding main branches as well (duplicating data), or do the text matches separately.
