(Rhino 5, Windows 10)
If I understand the Help file correctly, the Match Surface command only works on untrimmed surfaces. What tool would I use to match surfaces on a trimmed surface?
Hello - the short answer is, you cannot. Depending on the situation, there are things you can do to improve the situation - do you have an example you can post?
