Match string values for text, but output number for numbers?
What I want is to define the position of offsets from curves by using attributes. That way, I can use the curves as centre, but also as the edge for the alignment.
Therefore, I have created an alignment attribute that contains “Exterior”, “Interior” or a distance relative from the centre (to make it off-centre). I have several offset distances for each of the street elements (pavement, street, etc.), but in this example, I only feed in the two outlines as a simpler example.
I want to use a script component to do the matching and created the following script:
if Offsets == "Exterior":
    Result = Offsets+Width/2
if Offsets == "E":
if Offsets == "Interior":
    Result = Offsets-Width/2
if Offsets == "I":
if type(Offsets) == float:
    Result = Offsets + Alignment
print Result
I also tried to do it in two steps and calculate the offsets in a next step:
Al = []
Dist = (Width/2)
if Alignment == "Exterior":
    Al.append(Dist)
elif Alignment == "Interior":
    Al.append(-Dist)
elif Alignment.isnumeric() is True:
    Al.append(Alignment)
Result = Al
print Al
But it’s not working either way. Could anyone lend me a hand on this?
Offset centrelines by attribute and alignment.gh (21.5 KB)
Offset centrelines by attribute and alignment.3dm (6.0 MB)
Nevermind I replaced the occurances of the Exterior or Interior strings with the numeric value I need using replace text.
