Match loft between polygons
hi, i cant create a correct match between the exterior polygons and the interior pentagons. i tryed shift list component and changing data tree specifications with no sucess
could you help? :slight_smile:
Try the align option in the loft component.
If that doesn’t help, I’d try to flip the outer curves with the inner curves as guides.
If the alignment still isn’t right, you need to fix the seams. This can be done with a closest point or by rotating the planes for the inner pentagons.
If you can’t get it to work post your grasshopper definition with all necessary inputs internalized.
Thanks Martin!!
The Align option checked in the loft component or using the component “Loft Options” with True to align input also works!!!
Ricardo
I think you could get better alignment on some of the cells…
I will give it a try with the flip curves suggestion and place the results over here
