Have a group of lines (all the same length) radiating at different angles from a center point. I have another line (same length as those in the group) with a rectangle centered and perpendicular to the line. Can position one end at the center point of group but is there a command for moving the outside point so that it matches the orientation of the target?
You can set the CPlane by 3 points (CPlane). Its origin point can be at the center, where all the lines meet, and its two other points at end points of the blue and red line.
