Mass Sweep from Model Lines Causing Access to Protected Memory
Hi all,
Not sure if this is a bug or a feature or if there is something I should be doing on my end.
I have a Revit Plug-In and I have a mass void sweep command for patterning in families.
The hope was to sort out the model lines in Rhino and then sort out the mass sweeping with that plug-in. I end up in protected memory when the link is active, which, to be fair, is expected as I am making a sweep object and combining it with that active link, which sounds like a bad time. However, I’ve found that removing the link to rhino acts exactly as expected, but navigating back to rhino grasshopper triggers that same error even with the component disabled on the canvas.
Any help in preventing the crash on navigation back to Rhino would be helpful.
I’ve attached images of the call stack, the exceptoin and the state of Grasshopper.
