Thanks for the fast replay, this solution works for this simple case indeed, however I wanted to use the expression node to compact the algorithm, and the mass addition is an intermediate step of the formulation so I would like to avoid using it 100% otherwhise there would be no point at all to use the expression node in the first place.
