from time to time I run in the situation that I need to apply a object-size-matching mapping to many objects. For example I have a train with flat light objects on the ceiling, each one should get a planar mapping matching the bounding box. It’s a lot of clicks to select object by object and press the object-size-match-button. Please add the function for matching single objects in multiple selection. Maybe it can be added as right mouse button click on the current mapping object match button.
Hi Micha- as far as I can see that works as you are asking - you can select multiple objects and click the Match Mapping button once - do you not see that, or am I missing the point of your request?
I mean the button that match the mapping widget to the object size. Works great for one object. If I select multiple objects the bounding box of all object together is used (also useful for some cases), but I miss that each object get the own sized widget. (Sorry for my bad english.)
