In taking a 1) 3D surface (BREP or surface) to 2) Unfold it to a flat, to 3) place a pattern on the unfolded shape, to 4) reproject the pattern back to the original 3D surface (not working)…
The pattern doesn’t seem to map to the 3D version properly.
I’m it from my computer but this normally happens when one of the SRF is trimmed.
Check wich one is the trimmed, try the shrink trimmed SRF first and it should work.
Not super familiar with that tool or understanding of trimmed vs. untrimmed, but think your onto something.
The initial 3D surface made from a rail sweep is untrimmed, so not the “trimmed” one you indicate:
I wonder if it’s an issue in the unfold which can handle 3D to flat, but going back is much harder due to the orientation of the patterns on totally different planes…
TT Toolbox.zip (1.2 MB)
See if the attached version allows for it to work. ALl it does it unrolls the 3D BREP to a 2D Plane: Maybe there are other ways to do that with GH?
This issue may likely be a mix up of the original surface definition, and not the issue in this sketch, which appears solved with the proposed solution by Andy P. Will sift thru and try to redefine the surfaces properly so they are jiving properly and so the same approach can work.
Rechecked surfaces and clarified surface matching, however the same remap won’t fit the full target surface. Somethings off. the reparametrize doesn’t appear to apply.
OK. The solution works only when similar surfaces are used: Noted by skysurfer above: Maintain untrimmed surfaces, not to mix untrimmed and trimmed which causes issues. Solved!
