Everytime, when i import mesh object to rhino and try it mapping (cubic) and manipulation with mapping then rhino crash - every mesh, everytime…
Hello - so, you apply box mapping and then show the mapping widget and manipulate the widget directly, or with Gumball and you get a crash, is that correct? Does this only happen on mesh objects? How about a Rhino mesh - like MeshSphere
? If that works, please send us a mesh that does not… tech@mcneel.com.
thanks,
yes, you are right. I was send the file with Rhino crash report…In RH5 the same mesh is ok.
Not for mesh primitive, but for imported meshes…
