Manual Input Function
In ShapeDiver, may I manually draw a line in the viewport of the 3D model and set it as an input for further computation?
This is currently possible using the API and access to the three.js objects, however we are planning new features built in the viewer to do this in a more straightforward way. I will get back to you when those become available later this year. In the meanwhile, I will discuss with the team about creating a code example regarding the currently API possibilities to achieve what you need.
