Hi everybody,
I’m looking into a possibility to either create keys and values for a value list or manipulate an existing list.
Im creating a parametric script which should be usable without extensive grasshopper knowledge and therefore I have to handle a lot of possible user input and make changing things as easy as possible.
The idea is, to give the user a possibility to select certain elements from a value list which should be (not) included in a karamba fem calclulation. Since the model is parametric, I cant know how many elements are needed beforehand, so idealy I would manipulate a list to do that where every item is selectable and a single list entry which can either be 0 or 1.
I had hoped this is as easy as changing slider values with metahopper and there is a component I could use but so far I havent found a possibility at all. If scripting is involved, I would need somebody to give me a little nudge on how to do that (I’m fine with just a link for a python/c# ressource but I’m unsure where to start looking and my scripting skills are kinda basic). If it’s not possible I have to think of something else. Thanks in advance!
Edit: I should clarify that the question is not about picking the correct value from an existing list but about creating keys and values in a list.
