Manipulate hatches/polylines/surfaces etc
Hey there, I’m a beginner rhino user and there is probably a simple way to do this, but I can’t work it out.
I’m trying to manipulate a hatch without having to re-draw it every time i want to adjust it.
I’m aware of Scale1D but it doesn’t always work for complex shapes when i need to adjust one side.
This can be done with Grasshopper and the Gradient Hatch component.
The definition below creates a hatch aligned to the Y axis and the hatch axis is always matches the Y dimension of the bounding box.
hatch.3dm (43.7 KB)
hatch.gh (10.2 KB)
Hi Jamil -
If it’s the short side where the arrow is pointing to that needs to be moved to the side, you can turn on the points of the hatch, select the points at the ends of that edge and simply move those.
