Monochrome DisplayMode with soft shadows on GroundPlane visible in PrintDisplay and PDF when Raster is selected in the Print Dialogue (not working in BETA 27-09-2026).
TANGENTS
Monochrome DisplayMode with all Tangentlines optional invisible in PrintDisplay and PDF in the Print Dialogue (not working in BETA 27-09-2026).
EDGES
Rendered DisplayMode with Edges and Silhouettes visible in PrintDisplay and PDF generated via the Print Dialogue (not working in BETA 27-09-2026).
BACKGROUNDS
Concept DisplayMode with Edges and Silhouettes visible and Tangentlines invisible PLUS optional visible background as Transparent, Solid color or Gradient in PrintDisplay and PDF generated via the Print Dialogue > Rhino PDF. If visible backgroud is not selected or set to Transparent the Detail should expose elements placed below it in Draworder.
I’m not seeing that here.
Could you post your SystemInfo data and a relevant 3dm file?
As for those other points, unless I’m missing something, those appear to be feature requests?
When it is decided that a new feature is going to make it into a new version of Rhino, that new feature gets developed during the WIP phase of the process. The start of the beta phase is to iron out smaller issues, and toward the end of beta, the UI is frozen and documentation is finalized.
Hi Wim. I have sent a Zip containing my SystemInfo and a sample-file to tech yesterday. Today I have recreated a similar situation on a different laptop. It is only the actual PDF-result which has not the shadows on the ground in Monochrome DisplayMode. PrintDisplay show the shadows but also the lightgrey color of the Paper, which is not what you would expect in the “pseudo-preview”.
In Rendered DisplayMode you currently have a tickbox next to Edges, but the Edges doesn’t show. You also have a tickbox next to Silhouettes and they are clearly visible in the preview - and in the resulting PDF. It would be nice if there was a better relation between the preview and the result.
If this is not going to be implemented in Rhino 9 it is a “feature request” from me, yes. It would also be nice to get rid of the Tangent-lines in the new Concept DisplayMode. - In SketchUp you can just RightClick on any line (tangent, edge or silhouette) and select Hide. That would be ideal in Rhino 9.
Rhino use as a default a light grey for the “Paper” in all Layouts. - The color should be white, when you set PrintDisplay=On, since the light grey will be masked by any of the new Backgrounds in the Details as show in this example, where the soft shadows on the ground is why the Detail is so large.
On a different computer the Edges in Rendered DisplayMode are as I expect them to be, so it might be a display-driver issue on my Ryzen ThinkBook, where I could not see any of the Edges except the Silhouette lines. On both of my laptops I get a heavy “Banding” on the gradient 2-color background in the bottom left side below the six circular Details. On the next page right side in the Detail called “Bagside” there is no visible gradient in the Preview and no gradient in the final result.
