Hi, is there any tool I can use to get the surface to follow the curves smoothly? The goal is to make a closed brep. I have tried some different loft tools, but the result always end up like the pictures above. My intentions are to merge breps into a solid shape, and I suspect the loft can not leave any gaps if I want to have a solid.
Sorry for the headaches I caused. I loaded the right file now instead, which only touches on the problem I want to address. the quality is set on high. I also attached a dwg that I used as a block.
Thanks for the help, it was an improvement, (moved my block closer to 0), but my goal is to merge breps to one one closed brep, so I do not know if this will do. Is it something I’m missing?
