Greetings.
I work with laser scan data / point clouds. I recently discovered the PointDeviation command and hoping to use it in our drawings to show wall topography for installers. I have not found a method to capture the results in a way that can be shown in a viewport on our drawings like a heat map. The best I could do was screen capturing or printing to PDF while the command was still active, which seems a bit wonky as a workflow. How do you make it persistent and to scale for showing on a drawing?
Also, is there a way to change the point display type to solid instead of white centers for the PointDeviation results? Thanks in advance to anyone who can help.
Respectfully,
Brian Jackson
