Hi everyone, in the image example, if we use normal patch command, we get the expected result, but not with mesh patch command, it leaves extra unnecessary pieces, however, when I draw outline, then choosing it as a hole, and since it outside the object’s parameter, it will give you the correct shape, so is there a python script to do that conveniently in one step without needing to trick it?
Hi Moaz -
I’ve put this on the list as RH-84670 MeshPatch: Create Concave Mesh
I haven’t check this, but this post might be a start?
RH-84670 is fixed in Rhino 8 Service Release 14
thanks for you all, I’ll see what I can do
