Making a solid
I am looking for a way to make this surface a solid, but instead using Offset I’d like to have a elipsoidic interior of a solid. What would be the idea to make it work? Below is the 3dm. file
kompozicija. jungimas.3dm (1.7 MB)
do you have kind of minimum / maximum wall thickness ?
did you see this video / approach:
maybe a workflow like this:
use the initial curves
_offset (i used 20, the red wavy curves)
_rebuild (the green smooth curves)
_loft (the inner surface from green curves)
to get the final solid
_boundingbox
_solid
(delete unneeded volumes)
please provide more info if you have more requirements / conditions
kompozicija. jungimas_02_tp.3dm (1.1 MB)
Thank you for your reply.
I’ve managed to solve on my own by simply:
1 Drawing 3 inward ellipsoids at bottom, middle and top of the object
2 Lofting ellipsoids
3 Capping the main object (the “Curtain”)
4 Splitting the “Curtain” with lofted ellipsoids
