Making a paper model out of rhino file
Hi all,
I need to build a physical model of this structure (please see the pic attached)
I tried smash/squish command to get a flattened image, but the best I could get was separate 5 surfaces. I was wondering if there is any way I could turn this object into one flat surface if you understand what I mean. In other words, is there a command or plugin that enables printing the curved surfaces onto a flat paper, and then cutting it with scissors, and bending it in a way, a get a curved surface?I am attaching an image of what I want, if there is anyone knows how to do it, I would very much appreciate your reply!
Thank you.
Did you try the command UnrollSrf with the option Explode=No
Do note that this shape does not allow for the flat layout to be cut from one single piece of paper:
-Willem
Ah I didn’t know this command, I think it will work. Thank you for the tip! I have printed a model out using this command, wish me luck:)
Good Luck!
:four_leaf_clover:
-Willem
