Our company uses a 3D Digitizer plugin which is built with the help of [WintabDN library] (GitHub - aledelgo/WintabDN: This is a fork of Wacom WintabDN project). It was originally written for the Rhino 5 version but now we are using Rhino 6. The originally compiled plugin wouldn’t work with Rhino 6. So I compiled the code with updated reference with the most recent version of rhinocommon. When I run the code in the Visual studio it builds the .rph file successfully but when I try to connect the plugin at Tools—> 3-D Digitizer —> Connect . I see the error “Unable to connect to the digitizer.” I also looked at this post but I didn’t find it much helpful.
I suspect the problem might be coming from DigiPage.cs file which is like this:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Veada.JSON;namespace WintabDigitizer
public class DigiPage : Rhino.UI.OptionsDialogPage
WintabOptionControl winopt;public DigiPage() : base("Wintab Digitizer") { winopt = new WintabOptionControl(); if (WintabDigitizerPlugIn.Instance != null) winopt.SetShortcuts(WintabDigitizerPlugIn.Instance.Shortcuts); } public override bool OnApply() { if (WintabDigitizerPlugIn.Instance != null) { WintabDigitizerPlugIn.Instance.SetShortcutSettings(winopt.GetShortcuts()); } return base.OnApply(); } public override void OnDefaults() { if (WintabDigitizerPlugIn.Instance != null) { JsonObject defaults = new JsonObject(WintabDigitizerPlugIn.Instance.GetDefaultShortcuts()); WintabDigitizerPlugIn.Instance.SetShortcutSettings(defaults); winopt.SetShortcuts(defaults); } base.OnDefaults(); } public override bool ShowDefaultsButton { get { return true; } } public override System.Windows.Forms.Control PageControl => winopt;
I think the problem comes from the last line which is
I have to comment it out in my code because it was throwing this error:
‘DigiPage.PageControl’: type must be ‘object’ to match overridden member ‘StackedDialogPage.PageControl’
After commenting on the above-mentioned line out, my code still was able to build successfully but I suspect this might be the error! Thanks!
