Is it possible to ‘make2d’ of what is visible only in the current viewport? Also without having to select anything.
I think the closest you can get is to run SelVisible before running make2D. It will not give you partial selections though/ automatic clipping
Hello - see if this script works for what you want to do -
DrawVP.py (791 Bytes)
And for good measure, just the selection part, which may come in handy as well:
SelVP.py (793 Bytes)
To use the Python script use RunPythonScript
, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
