I was wondering if anyone has figured out yet why in the attached Make2D produces total caca for the closed polysrf “Bad” where the hidden curves bleed through while it does not do so for the polysrf “Good”. Problem Make2d.zip (1.6 MB)
Hello - try setting file tolerance to .001, then Make2D. The object is built to a very large tolerance, btw, considering how tiny some of the surfaces are. Fillets are .005 radius, for example far too small for a .01 file.
Yes, I see some of the fillet edges go missing - for now, to get the drawing done, it seems to pick up the edges if the object is exploded - I’ll see if we can get this fixed.
