Hi @GregArden
I have a problem with Make2D scene silhouette, it has lots of holes and isn’t joined. This seems like a bug:
The model is pure mesh, and I can’t post it here due to NDA.
(I can probably PM you a simplified part though)
Hi @GregArden
More things to fix:
Hei Jørgen -
Typically, the algorithm gets improved when failure cases are provided and the model can be checked on a developer’s machine. Please send the file.
Added a comment to the non-public RH-3578 (not public probably because it includes your eMail address that was pulled from your post on the NTTP forum in 2008 : )
You’ll want to send a file that shows the issue, though. The one that is attached to the YT item only has 1 curve that is shorter than the document tolerances.
I’ve now read through several 100s of posts in threads where this comes up and finally found RH-43678.
