Make2d(or Explode) Symbol of Clipping Section?
is there way Make2d(or Explode) Symbol of Clipping Section?
because Architects need Key Plan by location of Section Line(Symbol) in 2d Plan
if not please Add this feature (@rajaa @pascal )
Sorry for late reply. I don’t think I full understand the request. Can you please elaborate?
The cutting line of the section, which is defined as section _aa, should be able to be exploded and make2d for export to other software, such as autocad.
A possible work-around is to snap a line to the clipping plane and then project that line onto the object or objects.
Does ClippingDrawings command give you the result you are after?
