Make2d missing visible lines
Hi Greg
In the attached file there is an example of missing visible lines in the last WIP 6.0 16194.9151 12/07/2016
Make2d_MissingVisibleLines.3dm (920.7 KB)
Ciao Vittorio
@GregArden any thoughts on this one? I get a different result in the botd but it’s also incomplete.
Can you send to me your result?
Vittorio
I think you used different settings in the file versus your screenshot here so I tried both with and without hidden lines. This is what I get…
Looks like I made a step backward here. I’ll look at it.
I put this on YouTrack [RH-34925].
Hi Greg
In the last version the Gear is OK and only 2 lines (inside the circles) that are visible on the layer and should be on the hidden layer.
The bolt has some missing lines. Now is better. VittorioGear.3dm (2.2 MB)
Make2d_MissingVisibleLines.3dm (3.5 MB)
Gear.3dm (4.8 MB)
Hi Greg
In the Latest Wip there are still errors : missing visible lines.
Make2d_Missing_Lines_ Last Wip.3dm (9.6 MB)
Vittorio
Hi Vittorio I see some lines missing on the chamfers - is there more than that?
thanks,
No
Vittorio
