I’m working on some drawings and I just found out that dots are not showing on Make2D anymore in perspective view lines. In isometric view it works fine.
Also since the last update, the Properties tab looks empty. I need to close it and open it again to show the info.
(warning, this will reset your tools to default and you will have to reload any custom UI elements you have made, back up any custom toolbars before you do this)
if that fails,
go to add remove programs in windows and find rhino in the list.
I can’t tell that Dots ever worked in the Perspective projection.
I just tried in in V6 and no Dots in the Perspective projection.
V6 is when Dot support was added to Make2D.
Dots weren’t supported at all in Make2D in V5.
Jon, we have some drawings with dots in perspective view and we were pretty sure they came from Make2D but we could be wrong. Thanks for adding the enhancement request
