Hi
I have been using Make2D with WIP for some time now, but recently I have been getting less than desirable results from high poly meshes. I have tried increasing the tolerance, but that hasn’t made a difference.
Any ideas or suggestions would be appreciated.
Thanks,
A couple points. First use Showedges on the mesh. The edges that are highlighted have non-welded verticies. These edges will get drawn in Make2D. If you don’t want them drawn use the Weld command.
Second the tolerance of .0001 seems high try a lower number like .01. I’m not really sure why this effects the results so much I’ll take a closer look.
