Make2D Loads Forever Taking 100% of i9-24 Core CPU
I’m a junior architect working on this scene my senior colleague has given me. Neither of us can get Make2D to work with the front view in this model.
My machine is a 24-core i9, 32GB RAM with an RTX 4090. When running Make2D the application uses 0% GPU and spends about 39 minutes running at 100% CPU usage, so something is seriously wrong. systeminfo.txt (2.4 KB)
I believe I have followed as many steps as possible here also: How to Get Make2D to Perform Better [McNeel Wiki]
We have reduced the tolerance considerably, tried hiding objects etc. Rhino7 seems to hang and the cursor spins nonstop and there is no output or it seems anything for us to check what the issue is. In fact, a LOT of our Make2D models have the same issue. So I now need to reach out to try to understand what we are doing wrong.
I have uploaded the Rhino7 file in question to: Rhino Accounts
I would be extremely grateful for any advice at all. Thank you so much for your patience!
hi @AmHegg I’ll take a look
Thank you so much! I just sent the file via upload and included my email. Would be really grateful for any advice. Thanks also for the fast reply!
It looks like the terrain surfaces wreak havoc. I’m looking if there is a workaround possible. It might be their due to their high density. If you _ExtractRenderMesh on those surfaces, then hide the surface, Make2D is quite fast.
