Ok, simple 3d box with text and dimensions, run Make2d, Front View only, name and dims are correct.
Switch the Front view to Back, run the same Make2d, Back view only, annotations disappear ?
Maybe the annotations are hidden by the box when viewed from the back? --Mitch
yeh, wasn’t sure how this is meant to behave. I have also been using V6 eval at the office on windows and working between section tools and make2d to create layouts it reverses text so it shows correctly whether viewing from the front or back view. It’s quite an important feature when doing interiors, furniture, kitchens etc, as you often have instances of furniture which are mirrored or back to back if that makes sense
