I am using make2d to export a drawing to illustrator and the command only makes a few of my lines. Any ideas?
Are those mesh objects? Are you far from the origin? If so you might try moving everything closer to the world origin and see if Make2D works better.
Perhaps if you post a small sample file, some one can help more.
Hi, they are not mesh objects. It was far from the origin, but moving it closer did not help.
I will post a file on googlecloud
The goal is to make a drawing in Illustrator where I can overlay the rendered object over the linework. I’m posting an example of another composition
Hi - sorry in the delay on this one.
I see that you are using Rhino 5. This seems to work fine in the current release of Rhino 6:
