make2d - define output layers through scripting
I know how to script MAKE2D command:
rhino.command "-Make2D DrawingLayout=CurrentCPlane ShowTangentEdges=Yes CreateHiddenLines=Yes MaintainSourceLayers=No Enter ", False
but is there a way to define the output layers too?
( assuming that output layers already exists )
I could use VBS or Python example…
thanks in advance,
Aleksandar
You have the following command line options in order:
DrawingLayout=<CurrentView  CurrentCPlane  4ViewUSA  4ViewEurope>
ShowTangentEdges=<Yes No>
CreateHiddenLines=<Yes No>
ShowViewRectangle=<Yes No>
MaintainSourceLayers=<Yes No>
VisibleLineLayer <layername>
VisibleTangentsLayer <layername>
VisibleClippingPlanesLayer <layername>
HiddenLineLayer <layername>
HiddenTangentsLayer <layername>
HiddenClippingPlanesLayer <layername>
AnnotationLineLayer <layername>
That should allow you to put objects on layers you want. If the layers do not already exist, you should create them beforehand (via script or manually)
HTH, --Mitch
thank you very much!
Aleksandar
