I’m having an issue where the make2d function with a 3rd angle project on blocks results in a blown up axon. see below, the left side is with the blocks exploded and the right is blocked
Hello - can you post a simple file that shows this? My quick test does not but there are any number of possible differences - post here or send to tech@mcneel.com along with a link back here in your comments.
Hey Pascal, After some further investigation it seems that we can get it to work correctly by removing the text and any annotations. however, I’m seeing this in a fresh setup if i put text in a block.
Hi Nathan - good find… but so far it’s not happening here - can you post that box & hello file? There is annotation scaling and stuff… I’d like to see how yours is set up. @nbarnes - fyi, https://mcneel.myjetbrains.com/youtrack/issue/RH-55212 - thanks.
