Make UserString table read in async
When selecting a lot of objects with userstrings attached to them, then the entire rhino UI is non responsive if you have the userstring table opened.
This panel should update in async and not delay/kill the program.
Any news to this?
@Gijs
hi Mathias,
is it possible to send that model over? You can upload it here, pls link back to this thread.
Thanks for quick reply.
I will, but this is how every single speckle stream looks like from Revit.
I get that loading the [100 entries x 5000 objects = many many strings] is slow, but it shouldn’t stall the UI.
Perhaps just give the table a “loading” symbol etc.
Having an example file helps to log this issue. Otherwise it is hard to guess for the dev who is going to work on this what you are working with.
@sonderskovmathias thanks for the file.
RH-84210 Attribute User Text takes long time to load
