Make tool button launch a hint or method note?
V5
Is it possible to make a tool when clicked, launch a method note ?
I have a method offered by Pascal for getting split to work with apparent intersections but I wont remember what it is , where I have saved the method to, or that it exists without a prompt !
Can I make it that when I click the split tool a hint appears, perhaps with a link to the word doc location or a panel I can write the method in.
We are not going to remember all these workarounds and split apparent yes is a common used function, .
Steve
Probably. With a script you could launch a text box that would pop up on the screen for example.
One other workaround would be to modify the button on a particular tool and add a long-ish tooltip that has short hints. I don’t know what the character limit for a tooltip is though… Limited to one long line.
