I got a file made from some other software. I would like to have a solid that I can use to subtract, etc. I successfully made SectionArray with SectionTools, and so I have the attached file with a full wireframe of a chair (from an F15 or something)
Anyone have a magic button to make a solid from this??
there is no magic here. just few extrusions, boolean differences and maybe some Sweep2 rails. but it would be easier with the mesh object instead of the curves.
And then convert the resulting mesh to polysurface using MeshToNURB command.
You can also use Subdivide if you prefer to get smoother result. Obviously you need to use it before MeshToNURB.
Maybe if we could take a look at the original object (before sectioning) we could find better way to convert it to a polysurface.
