Hi Steve, if you are working from a button, you can change the macro to
! _Mirror _Pause _Copy=_No
On the other hand, you can use the RememberCopyOptions command to set how Copy=Yes/No is used by all the transform commands that have a copy option. Be careful with this… you may not like what it does to other Copy=Yes/No settings.
