Make hole in multiple objects failure
Almost there, but not quite…
Calling the command and selecting all three of the objects in the file results in a hole through the first one, a hole part way into the 2nd, and no hole in the third, UNLESS the cursor is dragged out sufficiently that the line indicating the depth passes all the way through all three…
In other words, the command wont work properly by just pressing enter to cut though all the objects…
cheers
rabbitmultpile make hole fail.3dm (156.9 KB)
Hi Rabbit - thanks, I see that - it works here in the latest with ‘Direction=NormalToCurve’ but not with Direction=Pick.
RH-60636 MakeHole: Enter to cut through objects fails
