Is it possible to either tell Rhino that an annotation style is all CAPS, or to Dup a font in (say, Arial) and make it all CAPS so you can apply the newly created ArialCAPS to an annotation style?
Hi Alan -
We have that feature request on the list as RH-64580. I have added this thread.
Thx. In the meantime, is it possible in a script to make Layout Text,etc, caps?
Hi @Alan_Farkas,
This might be a good starting point for a script.
import Rhino
import scriptcontext as sc
def __textobject_filter(rhObject, geometry, componentIndex):
return isinstance(rhObject, Rhino.DocObjects.TextObject)
def test_upper_case_text():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select text")
go.SetCustomGeometryFilter(__textobject_filter)
go.GetMultiple(1, 0)
if go.CommandResult() != Rhino.Commands.Result.Success:
return
for objref in go.Objects():
rhobj = objref.Object()
if isinstance(rhobj, Rhino.DocObjects.TextObject):
rhobj.TextGeometry.ClearPropertyOverrides()
s = rhobj.TextGeometry.PlainTextWithFields
t = Rhino.Geometry.AnnotationBase.PlainTextToRtf(s.ToUpper())
rhobj.TextGeometry.RichText = t
rhobj.CommitChanges()
sc.doc.Views.Redraw();
if( __name__ == "__main__" ):
– Dale
So it is impossible to use some sort of formatting in a text field to create uppercase text?
Something like this html code?
<p style = "text-transform:uppercase;">
Test
</p>
I guess I don’t understand the question. What is the workflow that you are trying to achieve? Why is the code that Dale provided not working for you?
