Make a ratio rectangle in any position
How do I make a ratio rectangle in any position
Use the orient component to create a rotated plane and use that as an input for the rectangle plane.
Thanks for your reply ! Sorry i didn’t make it clear!
my problem is “Make a fixed-area rectangle at any position within the area”
If the area and the aspect ratio is known, you can do this calculation to get length and width:
Or if the area and length of one side is known, you can get the length of the other side the same way.
Hello
if you want to populate a shape with whatever shape you can use Minkowski difference.
here an example.
Minkowski component gives a surface with the Clipper definition so it is an exterior and zero to many holes. As curve must be inside it means it is in the hole(s).
populate a surface with a curve.gh (10.9 KB)
