Make a plane from surface
i have one surface.
i want to make a plane from surface.
surface and the created plane are not in the same plane.
plane from surface.gh (8.6 KB)
you need to reparameterize the surface.
You are talking about a PLANE but you are actually creating a SURFACE.
If you want just the plane, you already have it when you do the construct plane, maybe you just dont see it because of your settings. Look at the tab DISPLAY>PREVIEW PLANE SIZE and increase the value.
Also, the output F (Frame) is already the plane you are manually constructing with P, U, V.
Otherwise if you want the surface another way could be this:
here you set the x and y domains instead of just a number
