Hello there,
I would like to create a hole in a polysurface. The thing is the hole should be wider on one end than the other. In this example I have drawn a 5 mm dia circle on the top surface and 3 mm dia circle on the bottom and wanted to somehow extrude a polysurface out of it, so I could later use it as bollean difference:
Thing is that does not work. I bet there is a better approach that I don’t know of. I would appreciate all feedback!
