I’m trying to export several objects from a model into Illustrator using the make 2d command. I’ve attached two images that show what I’m trying to do and what’s wrong. I would like to do the make2d command several times from the same view with different layers off and on so that I have all of the elements in place so I can bring them into Illustrator. I hope that makes sense. But, when I make 2d from the same view with some objects turned off the 2d version doesn’t appear in the correct place compared to the previous time I did and it appears smaller.
If you see the image, I’m trying to do make 2d two times once with the foreground square turned on and the rest off, and with the foreground square off and the rest on. I want the 2d forms to “land” proportionately to how they are in perspective so that I can bring them into illustrator and diagram them. The problem as you can see is that the foreground square doens’t appear where it should in the right panel, it appears small and near the bottom of the chair wheen it should be large and in front of the sqare in front. Let me know how I can export them all at the correct location and size. Thanks
