Make 2d WIP
I was curious if anyone had an experience where a Make 2d on an exploded polysurface would work but not on the joined version? It ends up being about 30,000 faces and as a joined object it’s a valid, closed polysurface with no naked or manifold edges. When I explode and Make 2d it takes about 20 seconds, as a solid however I get a Server Busy window.
Thanks
-J
I’ve never seen that. In fact it should be faster if it is joined. Do you have a model you can send me? If so you can use https://www.rhino3d.com/upload to send me the model.
Greg Arden
greg@mcneel.com
Sure thing, thanks for taking a look.
John
Thanks, I got the model.
