Follow the instructions in this file to see the fault.
This was created by making the 2D in another instance of V7, pasting it into this instance, then changing the curves to a different layer, with print display active.
The 3D objects (included in the file) don’t exhibit this behavior when made into 2D within this actual instance, but the pasted ones still do, and you can repeat and watch it happening by simply changing the objects to the different layer.
cheers
rabbitmake2D fault V7.3dm (764.0 KB)
cheers
rabbit
