Maintaining Accuracy With Angled Sections Along a 3D Curve
I have a problem that I need some help solving. I’m using sections placed along a curve, and then I use Sweep1 to create the geometry. The curve varies in the x, y, and z directions.
Here’s what the sections look like:
The geometries turn out really well when the sections are placed perpendicular to the curve. Below you can see two geometries that meet:
The issue arises when I have sections that need to be angled. As you can see in the image below, the geometries are formed incorrectly:
I then use this calculation to rescale the angled sections and sweep them again. See the image below:
Crv = section
Pt = section top point
5.5 =section width
At a quick glance, it looks okay when sweeped:
But if you place it next to the geometry without angled sections, you can see that the angled ones have a slightly different shape. See the images below:
Does anyone have a solution or an idea of how to achieve a more exact result? Any help would be greatly appreciated!
Best regards,
Mikael
No GH code with internalized geometry :question:
3. Attach minimal versions of all the relevant files
It’s likely that the issue you are having arises from simplistic assumption that you can simply uniformly scale the angled profile. Too see this, compare the scaled angled profile with a profile that you get when you slice the geometry you created from perpendicular profiles at an angle. You will see that this section is not a simple scaling.
Hi!
Thank you for your response. I’ve attached a Rhino file and a Grasshopper file here. I hope you have time to look at them.
rotate_scale.3dm (46.0 KB)
rotate_scale.gh (9.0 KB)
