Magnetic lines
Surface 1
When creating surfaces from curves (curve network):
How can I keep the point where the lines intersect locked together (magnetic to each other) so as to move them up or down together to fine tune against a reference mesh?
that does not work, why dont you use a surface instead? if you then need curves from the fitted surface still, you can extract the isocurves at any time.
