The MAGIX-LOCK closure system is a patented innovation taking advantage of the power of magnets. Instead of the normal attraction of magnets, the magnets are reversed and repel each other forcing the object to lock in place. Once the female and the male parts of the closure system are joined and locked, they can be released by applying force on the male part to unlock the system.
The preliminary design concept served as the first step in the production process of the prototypes. The analog sketches were transferred to the digital space and constructed precisely in 3D by using Rhinoceros. The first generation of prototypes in different variations was 3D printed based on the Fused Filament Fabrication and manually assembled with efficient Neodymium magnets. Based on the result of the first generation prototypes, the 3D models were further optimized in material thickness and fabrication tolerances in Rhinoceros.
The second generation of the improved prototypes was cast using the lost-wax technique, which better reflected the precise feel of the final materials and appearance.
The current third generation of the prototypes has been completely re-engineered, improved in functionality, and constructed to be produced entirely with CNC milling, which is focusing on mass production. Rhinoceros has been an integral part of the design and construction process which served as a direct output for the final fabrication process (sketch-construction-production).
This simplicity of the MAGIX-LOCK functional design opens up a whole new line of closure systems, ranging from watches, jewelry, bags, helmets, and many more.
MAGIX-LOCK PROTOTYPES from imagodesign on Vimeo.
Posted Jul 15, 2019 by Carlos Perez on Rhino News, etc.
