Magic before node output for curves
I have this very strange situation, where the exact same code doesn’t work as continious code, but as soon as I output the exact same curves and put the second part of the code in a separate c# node, the code runs as expected:
maybe I am missing some code to “finish” the curve or some hidden magic done when the curve passes through the wire…
getKinksProblem.gh (110.7 KB)
can someone help me understand this strange situation?
I once spent two hours fighting with circle parameterization and experienced the same issue as you - code was working separately but not in one go.
The magic is that the Curve input of a component converts to NurbsCurve.
Adding this method there seems to work.
Thank you very much Ted! It indeed works and finishes my two day frustration.
I still don’t get why it’s EXCLUSIVELY working like this, as I do transform the circle to a NurbsCurve before the offset and had tried to add “ToNurbsCurve()” one line before: dCo.OffsetNormalToSurface(blabla).ToNurbsCurve(); which didn’t work either.
If someone knows more on this topic, I’d gladly listen. In any case thanks to @magicteddy for the solution!!
